1 - 3 of 3 Posts
I may have parts not listed, some parts are Firm, some are best offer, so let me know
01-02 motor with 1070 cc car kit:
Freshly built with less than 100 kms - drove home from the shop, no passes, no dyno runs. Bike was parted out cause I ran out of cash. Head by millennium technology, Motor Built by Gord Bush in Ontario
Freshly built 1070 kit motor;
nickel plated cases, 750 intake cam/exhaust, cam gears, shaved head, mechanical chain tensioner, NRC covers, JE pistons, hoses/ wiring/ ECU/ power commander,air-box, cables, velocity stacks,
everything - $3000
Just motor - $2500
Parts that will work on the following GSXR models: 00-03 750, 01-03 600, 01-02 1000
blue and white tank with fuel pump $260
1000 throttle bodies+ injectors $200
Velocity Stacks $180
brake master, galfer lines, calipers, ebc pads $180
2 clusters, each $100.00
Rear caliper/galfer line/ebc pads/caliper $80
2 1000 ECUs, each $80
1000 wiring harness $120
set of injectors $100
stock sprockets 525/530 $40 for all
Key set with key $140
truck lock mechanism $20
blue no cut sliders $50
fuel pump $100
stock exhaust complete - $100
stator with cover $140
passenger pegs $40
1 mirror and misc clip on parts $25
Parts that will work on the following GSXR models: 00-05 750, 01-05 600, 01-04 1000
rear set raisers $80
2002 braced powder-coated swing-arm with axle-1 $140
Shifter lever $50
Parts that will work on the following GSXR models: 01-04 1000, 04-05 600, 00-05 750
front inverted shocks with ohlins internals $760
triple trees $80
rear swingarm with axle $100
03 1000 EBC pads 2 complete sets BNIB $120
03 1000 EBC pads 1 complete set used $40
Parts that will work on the following GSXR models:06-07 600, 06-07 750
1 right mirror $30
damaged tank fairing $40
clip on signals $40
misc fairings $40
exhaust flap actuator $50
Rear OEM shock $100
trunk lock mechanism $20
kick stand $20
99-02 SV650 525 rear vortex sprocket new +1 $40
Sold
1000 cases and misc parts
06 gsxr 600 seat
00-03 front rotors
rear rotor
complete fairings
pazzo levers
clip ons
subframe
Ohlins rear shock
Assortment of frame bolts and stuff
mirrors
06 headlight with broken tabs
02 headlight
TRE
K&N filter
Rad and rad fan
Marchesini rims with 520 sprocket
battery
OEM rear sets
520 DID Xring chain used
clutch Cable and cover
master cylinder
front/back galfer wave rotors
Yosh full system
Fairing stay
power commander
clutch lever perch
caliper bolt
scrubs
06 stock muffler
rear caliper carrier
02 600 frame
passenger pegs
03 Front OEM rotors
02 1000 stock rims
525 DID xring chain
03 stator cover
02 starter
updated gallery with more pics
Picasa Web Albums - Terry
1 - 3 of 3 Posts
