I want to know if there is ne way that I adjust the stock rearset on my bike to where its easyer to change gears, its an 02 gsxr if that matters/
you really dont want to do it this wat. You are changing the leverage on the shifter shaft when you do. The rod that connects to the shift lever is made to adjsut the lever position.audi1031 said:on the shifter you should see a bolt right where you take off the shifter and what you would do is remove the bolt (10 mm) then slide the shifter off and move it to another tooth or grove and that will give ya either more room to get that big ole foot under or less to blip it up with front of foot
if ya don't understand i will take picture later on
They wear big shoesyamahaspanker said:well you know what they say about people with big feet
