If i remember correctly you hold the SEL(select) button with the key off, then after holding the SEL button for about 5 seconds turn the key to on. Then i think itll do its little start up thing and quickly go to where the light currently is set to blink. now im cant remember if tapping SEL or ADJ moves where the rpm setting is. If the select button moves it then the adjust button will change or light setting (off-blink-flash) just play around and you should figure it out pretty quick
I have the same bike , for imma too busy looking up in stead of the shift light. Are you a new rider. :thumbup:
Keeripes, what a dildo. Anyway, Press SEL button and turn on ignition, hold button for more than 2 seconds to change mode.
push the adj button to change lighting mode
push sel button for brightness, then push adjust to alter this.
push sel button from brightness to adjust rpm, push adjust to move limit up in steps of 250 rpm up to 10k and steps of 50 rpm beyond.
then push sel to lock the settings
K7
