OK......so I give up and need some advice. Bout three months ago received all kinds of great advice on gettin the air outta my front brake system after I had to unhook the master cylinder from the hose for a handlebar mod(if interested read thread "where does the air hideout" )
For three months have had the symptom of whenever the ambient air temp. rises even 10 degrees the front brake begins to drag and will bring you to a stop. have a little 8mm wrench wired right to the base of my brake fluid reservoir and must release just a little when it starts to tighten up. Tried everything imaginable, unsucessfully to fix this 06 GSXR-1000 with 7000 miles (when problem began.) So if I'm going to start replacing parts i guess I'll start with the master cylinder because for some reason I suspect that it is entraining air into the system whenever the brake lever is released from the compressed position>> As I've completely disassembled both the calipers completely and the master cylinder and only ever found light scuffs on the master cylinder piston as the only abnormality.
If I'm buying a new master......do you guys suggest switching to an aftermarket one? is there even an aftermarket one available. I do no racing whatsoever and just ride the streets. Guess I'd like to have one that has the bleeder on the master cylinder if possible
Things I've tried:
-six foot 1/4 inch tubing to the ceiling bleeding method
-Mityvac. bleeding holding the calipers hoses,and master cylinder
in various positions as the oil flows through them.
-COMPLETELY removing the entire front brake system from the bike INTACT(had to take the front master and reservoir down through the front faring compartment and out the bottom) without unhooking any hoses so that I could bleed the line from the master cylinder up to the right caliper with that caliper ABOVE the master cylinder..used vacuum bleeding as you couldn't easily compress the brake lever unless you put somethin between the pads I guess
-have pushed all eight pistons as far back as they will go in attempt to get any air out from behind them..did this three different times holding the caliper in different positions in case that makes a difference in whether the air can get out
-used tapping methods during all these various methods to try to move bubbles up to the bleeder I was evacuating fluid from
-first month and first six bottles of DOT 4 was cheap prestone synthetic stuff from walmart........in last several attempts have completly taken system down and caipers completley apart and cleaned a second time and then changed to MOTUL racing 600 DOT 4 fluid......two bottles at $17.95/bottle
-have inspected all the lines and no aneurysms anywhere
-micrometer on both front rotors showed less than two thousanths of and inch wobble in either disk.
Please someone make me feel like a complete FOOL with the correct diagnosis of this problem or tell me where to get a different master cylinder, if I should. Only thing NOT stock about front brake is when I moved the clip ons above the triple clamp I had to turn the hose connector where it hooks to the master cylinder upside down and then slightly bend it to make it clear everything. No leaks of fluid anywhere.
Things I've tried:
