Does anyone know where I can find this little piece that sits in between the fairing and the screen?
296095
The little piece under the windshield ahead of the instrument cluster?
Have you checked one of the online parts diagrams?
It looks like a little reflector. I can’t seem to find it anywhere. Even on eBay. When I try to check it with diagrams it’s not labeled.
Reactions: Todd_Sails
There's some tape on the lower part of the windscreen but you seem to have circled the running light. It's in the headlamp section. Suzuki changed to a single centrally located running light in K7, apparently because of the tight space due to the active damper. See #8 here. Unfortunately the W5W bulb has a short life and is hard to replace. It's best if you switch to an equivalent LED bulb.
P.S. There also are aftermarket windscreens intended for use by racers that extend into that space to eliminate the light.
