1 - 3 of 3 Posts
Hi guys
I am working on a possible transformation for a k6 wiring and ecu swap for a k7 one.
Reason? I have more options available in that ecu and also fast data available for data.
I know that some sensors like cam is different (from 2 to 3 wires) just by changing the sensor would work? Has someone done a similar mod?
The ecu will have obviously the correct info for the k6
Thanks
Sent from my Mi A1 using Tapatalk
Sounds ambitious
What kinds of things are you doing with the data?
Well, with that ecu I have more options to work with and also a br of 50.000 compared to 10300 (I think it was a br 10300 from factory) allowing faster work and results to be thrown on tests
1 - 3 of 3 Posts
