how many miles do you guys get on full tank of fuel, and what kind of gas do you use? 93 octain?
thank you :hmmm:
thank you :hmmm:
true....i get about 150 mi. to a tank with normal riding.you da man said:You guys are wasting money on 93 octane unless you have done some serious engine work. 87 octane is fine. Suzuki doesn't blow millions of $$$ on research and development to find out their 600 runs best on 87 and then have a average Joe street rider think 93 is best. But if pumping in 93 octane psychologically makes your bike run better that have at it. Hell the race fuel we use is 87 octane and I gained 4hp's on the dyno with it.
wickmaster said:I gotta say you are wrong here. Read your owners manual. It says to use premium fuell only with a pump octane of 93 or higher.
scott2t2 said:not on the 600's. my manual say "87 octane or higher"
The HP from race fuel is because of the additives, not the Octane.you da man said:You guys are wasting money on 93 octane unless you have done some serious engine work. 87 octane is fine. Suzuki doesn't blow millions of $$$ on research and development to find out their 600 runs best on 87 and then have a average Joe street rider think 93 is best. But if pumping in 93 octane psychologically makes your bike run better that have at it. Hell the race fuel we use is 87 octane and I gained 4hp's on the dyno with it.
I know thatskibum91 said:The HP from race fuel is because of the additives, not the Octane.
And you should run the lowest octane you can without pinging.
Yep...600's use 87. 750's and 1k's use 90+ octane.wickmaster said:Well. In mine it says....The GSXR1000 is designed to run on fuel of no lower than 90 octane. So I was wrong too. It also states to run only premiun fuels only.
you da man said:Yep...600's use 87. 750's and 1k's use 90+ octane.
right on wick......wickmaster said:I thought I was right. It also states not to use oxygenated fuels also.
I realize the manuel does say not to use oxygenated fuels, however, I had a separate map made for my PCIII for VP Ultimate 4 and I just switch my maps for races and stick to pump gas for trackdays. Also I drained the tank after using U4. Now I have a race only bike so the GSXR 600 is strickly pump gas once again. For what it's worth, my GSXR600 is an 02 with 32,000 miles on it, has never seen the inside of the service dept at a dealership, valves checked regularly and never had to be adjusted, and all this with 30-40 trackdays on it. I love my baby Gix.scott2t2 said:right on wick......
