I have a 03 gsxr 600. I replaced the cam tensioner and the noise is still there. I had another motor and dropped that it the noise is still there. F1 is blinking on and of like the bike is tipped over. When i swapped motors i used the same coils and throttle body off the old motor. Does anyone have an idea whats the wrong with my bike. or anyone know what or how to get a trouble code off my bike.
You have to explain in more detail buddy, the engine makes a lot of noises, and are you actually throwing a code? we need more info to help you.
Mine will sometimes not start when I try. It also throws a code. The reason for mine is that I have the throttle open too far. Turn the key off and retry and its fine.
More detail
The code is blinking on and off it says Fi kinda like the bike was the bike was tipped over. and goes back to the bike temp. it sounds like a vavle or something smacking. but i know its not a vavle. could it be an injecter or a ignition coil?
do you know how to bring up dealer mode?
