1 - 2 of 2 Posts
2007 GSXR 750 has two wires under the seat (black/white) / (Grey). The question is: what are these wires and where does the grey wire connect? When I connect the black/white to the negative terminal, the bike starts but blows a 15 fuse. When it's disconnected, the bike turns on but won't start! The blown fuse is missing in the photos
Administrator
Welcome to the forum.
The black/white striped wire is the universal ground wire on these bikes. There is 2 wire connector with a B/W and light grey wire which goes to the right turn signal. Are these wire just loose?
If the bike won't run without the B/W being put to ground, you have a ground circuit problem somewhere else.
You need a schematic and a meter to hunt this down.
1 - 2 of 2 Posts
