that shift light will stay, its problem ? if that no problem I cant touch and dont change settings. if that problem I try make change for light but I dont do it.that light is for the shift light. when it is on, the white shift light will come on at the RPM you set it at. read the manual to set the shift light
I'd like to help but I have no idea what you're saying here:headscratthat shift light will stay, its problem ? if that no problem I cant touch and dont change settings. if that problem I try make change for light but I dont do it.
what :hmmm:I'd like to help but I have no idea what you're saying here:headscrat
I am scare see that lamp, so I dont understand what is lamp,I'd like to help but I have no idea what you're saying here:headscrat
its not a problem. its just telling you that the shift light will come on. read the manual if you want to remove it or change the RPM of when the light come on.I am scare see that lamp, so I dont understand what is lamp,
if no problem that lamp, no problem for me![]()
Thank you very much, :thumbup:its not a problem. its just telling you that the shift light will come on. read the manual if you want to remove it or change the RPM of when the light come on.
Thanks, I will try thats.With the ignition off press and hold "select" and turn on key while holding the button for an additional 2 seconds, it will go to program mode. First is mode 3 choices "light" blink" and "no light" use adj button to change.
or:
1. Turn key to on position
2. Change selection to ODO
3. Hold down SEL & ADJ buttons until you are in adjustment mode.
4. Use ADJ button to choose shift light mode (flashing, on, none)
5. Push SEL button to then change brightness
6. Adjust shift light brightness using ADJ button
6. Push SEL button to then select RPM shift light should come on at.
7. Use ADJ button to change RPM level for shift light. (You will see needle on Tach
move each time you press ADJ button.
8. When desired RPM level is reached, push SEL button one last time.
your welcome, good luckThanks, I will try thats.
or:
