Hello, my motorcycle started having problems, the GSXR750 K1, at low revs seems to be working fine as I need a quick move to drown, cleaned the tank completely with its filters, replaced the fuel pump, cleaned the injectors, replaced the spark plugs and air filter, checked the full bobbin, Still has the same problem, please someone tell me something.
I see you did some work and you say it runs fine at low revs but what is the problem?
Has a fall and runoff during high gas
The first thing I would do is a fuel pressure and flow test per the service manual. If you got something together wrong, or the new pump is incorrect or bad. It will cause a symptom like you have.
