Busa rims are the exact same rims as a GSXR 750 so you will need to change get the spacer from busa (which is smaller )
on the front wheel you can get it to fit but and roll it just as it is but you will more than likely use the front wheel bar off the busa because it is lil longer. I have done this on mines when i sent off my wheels to get chromed and road with it like that all day long and also you will need to get the hub and the sprocket carrier as well. change front sprocket busa/srad run 530 chains and yours is a 525. You also need to get the front and rear disc too from busa
So basically you need:
wheels front and rear complete with disc,front rear sprocket,hub,sprocket carrier,chain.
Busa rims also look diffrent from newer GEN gixxers as ours are like diamond cut and those are roundish. best to get just a rear 1k wheel instead
