1 - 2 of 2 Posts
Hey all, i bought my gixxer with a busted clutch lever so I put some OEM ones on tonight, only exception was the color. The brake lever is real smooth and I'm very happy with it. The only thing is that the clutch lever is sorta hard to engage, not overly hard, just harder than the stock one. I didn't put any grease on when I changed them, is that the problem? If so, what part do I put the grease on? Thanks
did you change out the cable too or just the lever?
If you swapped out the cable too you should have lubed it up a little first. As far as greasing the lever you will want to grease the pivot point area. Just look and see where it pivots and work some grease in there a little.
1 - 2 of 2 Posts
