1 - 13 of 13 Posts
i have a gsxr600v 1997 bike after getting it out to start getting it ready for this year the electrics are all dead apart for the neutral light. ive checked the fuses but thing it mite be the ecu box under the seat? has anyone had the same problem and can anyone help
What do you mean they are all dead?
Does the battery have voltage? Have you checked it?
If yes, does the fuel pump prime when you turn the key and kill switch to on?
If no, sounds like a switch problem
If yes, sounds more in depth, and we will need more info.
my bike is dead
ive turned the key ive check the kill switch and the battery and even the side stand but she is still dead the bike did run for about 5mins before cutting out now every this is dead not even the light work? anything you need to know?
Put a digital multi meter on the battery and have someone else start the bike. While you're starting it, the battery will probably go to zero. It sounds like you have a "dead cell" on your battery. You did say that you checked it, right? Did it have full power?
the battery is a new one so i know its not that.at the moment nothing works apart from the neutral light. and when you turn the key to the on position there is a click sound from around the battery and ecu area? :bowdown:
Just because it is new doesnt mean it isnt dead.
you need to put a meter on it, see if it has 12v
i hear what you are saying but on my bike when the battery went last lime it was a constant clicking sound under the seat. the bike did start up and did run for about 5mins or so. then all the light went out and the engine dyed. i turn it off then turned it back on but there was nothing? dose the ecu controll all the electrics or is it just for the engine? if you have a copy of a wiring diagrans for the GSXR600V that would be a great help in my hour of need. thank for your help :headscrat
HAVE YOU PUT A METER ON THE BATTERY!
I seriously doubt it it the ECM. Put a meter on the battery, and let me know what you get
Discussion Starter · #9 ·
ok ill try that but cant get to my bike untill the weekend so ill speak to you some time over the weekend.
check your wires, an exposed wire will do the same thing, make you think your battery has a dead cell. I pulled a bald spot until i found it .
Yea, if a wire is arcing off of your frame or subframe, or something else metal, then it could be causing that too, but first start with the battery, check the voltage.
Discussion Starter · #12 ·
thanks guy ive sorted the bike out i checked every think like you said and i fount some bad wires which needed some TLC. :clap:
Sweet. Makes you feel good when you finally find the problem and fix it, right? I always just try to find a starting point and work backwards until I find it. Now when it warms up, you can ride it. :cool:
1 - 13 of 13 Posts
