You can make it work by changing injector connectors...
Can I clip the stock injector connectors and put them on the pc3, put the connector that came on the pc3 on the stock wires and then snap the other connectors from the pc3 to the stock wires? If so do you know what injector j start with cause one end of the line if connectors from the pc3 is different, same plugs just different way if wiring them I'll send pics
Hand Electrician Hood Finger Electrical wiring
Motor vehicle Automotive tire Hood Automotive lighting Automotive design
The first pic is from the last connector on the pc3 and the second pic is the first connector closest to the pc3
