I have a 2001 750 GSXR I got run off the road hit a ditch and the bike had rust in gas tank now it won't start can spray it with starter fluid and it'll start fine and i
change the pump injectors filter the housing need help don't know where to go from here
I'm assuming that you hear the fuel pump running? I'm also assuming you do not have any FI codes.
If so, do a fuel pressure and flow check as per the service manual.
Even though you cleaned things, does not mean the pump is performing properly or that you did not damage an o-ring putting the pump back in.
I replaced the o rings pumps running fine I looked in the tank no bubbles coming from the pump I do not think the injectors are opening up like they should I replaced the injectors with new ones too
I don't have a compression tester to test the injector
Your description and knowledge seem all over the place. I suggest either giving a better description or taking to a dealership.
There are two fuel filters. The one you see when you pull the assy from the tank is a coarse sock before the pump. There is a secondary filter inside the pump that is easy to miss. Back flush that and it may help. Getting the tank clean is the first step,
