1 - 20 of 29 Posts
PICS ~EDITED~750 question
Hey i just bought this 96 750. Now it has a racing front end and rear end( with no second seat) its Red and black ( stock colors) but the rear fender is checkard flag with a big 4 on it, and the front is the same. The front peice didnt have the stock light hole im guessing so he put car circle fog lights in it. I will have to get pictures online to show you guys. Its a real nice bike. Got the yoshimura carbon excaust ect. But my question is Can someone show me a stock one with the stock front fender? And what should i do to make it pass inspection. ( not inspected ) Its only got the left mirror and the fog lights. Thats what im guess is causing it not to pass.
You need any help on that bike gimme a holla. Take it out to roll on out in oakdale. He'll inspect it for you. My 1K has not had a sticker since I got. I just say hell with it.
Is this what your looking for?
Specifications
Engine: 749 cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
Bore x Stroke: 72.0 x 46.0mm
Compression ratio: 11.8:1
Carburetor: Mikuni BDSR39SS x4
Lubrication: Wet sump
Ignition: Digital/Transistorized
Starter System: Electric
Transmission: 6-speed constant mesh
Flnal Drive: RK50MF0Z1 Chain
Overall Length: 2055mm (80.9 in.)
Overall Width: 720mm (28.3 in.)
Overall Height: 1135mm (44.7 in.)
Seat Height: 830mm (32.7 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1400mm (55.1 in.)
Dry Weight: 179kg (395 lbs.)
Suspension: Front: Inverted telescopic, coil spring, adjustable spring preload, rebound damping, and compression damping, 43mm stanchions
Rear: Link-type, gas/oil damped, adjustable spring preload, rebound damping, and compression damping
Brakes: Front: 320mm dual hydraulic disc
Rear: 220mm single hydraulic disc
Tires: Front: 120/70 ZR-17
Rear: 190/50 ZR-17
Fuel Tank Capacity: 18.0 liters (4.8 gal.)
Discussion Starter · #11 ·
wickmaster said:
You get that bike off Frank? I know this bike. I worked on this bike.
I bought it off Dan collier. I dont know if he bought it off frank or not. I know where roll on cycle is i oakdale. Me and my boys use to ride in the woods up by the apartments on our quads and dirtbikes. How much for the inspection? And what do i need to show ?
Those lights should be legal. I would not worry about them. All you need for insp is registration and insurance card.
I think I know dan i'm not sure. Now I think about it frank did sell that bike in aug or sept.
1 - 20 of 29 Posts
