What's the best way to lowered my 07 gsxr600?
Lower the front by loosening the bolts that secure the clip ons and the triple just enough that you turn the fork tube inside them and work it up to the desired height, do yourself a favor and only do one side at a time.
You cant lower one side at a time, at least not more than 1/8in at a time. I had to loosen up both sides before mine would move anywhere.Lower the front by loosening the bolts that secure the clip ons and the triple just enough that you turn the fork tube inside them and work it up to the desired height, do yourself a favor and only do one side at a time.
yeah my friend bought a 06 and it was lowered by dropping the clip ons down. He cam down from a wheelie kinda hard and the left clip on slid off cause of them being tappered. so after that we rased it back. the easiest and safest way would be to strap it or find out if they make a shim for the forks
would you be able to send me some pics of this pls. [email protected] thankswhat you need is a ford small block rod bearing(305) i used it, it works perfect. Just buy one from advanced for like 3 bucks use 1/2 of the bearing on each fork it will go in and be a nice snug fit and you wont have to worry about the forks sliding out.![]()
