I bought a new ignition switch cause my old one was getting hard to turn on.So i get the new one and think I will just undo the two bolt and slap the new one on lol.But it dose not work like that I cant get to the top of the bolt cause they are under the triple tree or in it or something,all I can see is the bottom of the bolts and there are no bolt heads on there that I can see how the heck can I change this thing any one what I need to do?
Thanks Moose
:headscrat
what bike?
What does the bolt look like? The easiest way to take care of it, is pull the upper triple clamp off and turn it over. On the new bikes they require whats called a Security Torx bit, which you should be able to get at home improvement stores or automotive stores. Not sure if its the same but I'd imagine it would be. It just looks like a Torx bit with a hole in the middle.
