1 - 20 of 21 Posts
ok, how the fuck do i loosen the damn motor mount to install the frame sliders?? i'll get a hernia trying to use an allen wrench...geezus :2hard
either side....i'm supposed to remove the stock motor mount (which i dont think has a nut) and bolt on the frame sliders using the longer bolt provided with teh frame sliders.....they're a little longer than the stock bolts
use a breaker bar (a long pipe which will fit around the wrench/ ratchet) this will make it a whole lot easyer... assuming as fishy said there is no nut on the other side you need to put a wrench on the other end to prevent it from moving
dammit i'll just take off the fuckin fairing, i was trying to avoid it but screw it
a breaker bar will scrape up the fairing, i barely have room for the allen wrench as it is
Well stop being lazy and take the fairing off and use a breaker bar to make it easyer
Yes you are, but thats not because you can't get the bolt loose, thats just using improper tools, you need an Allen socket, 10mm I belive, and then use a long ratchet. Thats the easy way to do it.
lshybrid195 said:
was size allen is it i might have it in the socket allen
:headscrat :headscrat :headscrat
Yeah thouse ratchet ones are so much easyer..
Anways if you dun have the correct tools still bring it back we have just about any and everything
Discussion Starter · #16 ·
hahahha, its cool i'll go buy it...i'd rather fork out $5 and buy it then drive 30 minutes to the OC to pick it up :thumbup: this way i have the tool from now on anyways
Hahaha I didn't mean for you to come grab it and leave I ment if you where still having trouble or trying to install your other toys and found out you need a lot more. Different tools you could come. Besides if I gave you mine then I would have to buy a new one... Remember my garage is sponcered by craftsman thanks to fishy use to work at sears.
Are you going to hooters friday?
there is a "pinch" bolt that keeps the motor mount bolt from coming loose. take the fairings off and you'll see it. loosen this bolt then remove the motor mount bolt.... they are not that tight once you see what i'm talkin about. if you just put a breakerbar on it you might strip out the head and then you'll be royally screwed.
1 - 20 of 21 Posts
