I have a suzuki gsxr k7 600. which the immobiliser light is on even when the ignition is on. the bike does start but lacks in power any help would be great thanks
Immobilizer
It sounds like you might be in fail-safe mode. Have you tried dealer mode and, if so, are there any codes?
Does the immobilizer indicator light flash when you first turn the key on?
Immobilizer
I have tired dealer mode it's just giving me fault c28 and c29. No it just stay on with key in or out I dims slightly with the ignition on
You need to sort out the C28/C29 errors. The manual indicates that they will put you into a minimum performance fail-safe mode. It's possible that the immobilizer light is an indicator of that.
Great thanks for you help I will fix that. Will I need to clear the fault or will it do it it's safe thanks
The code should go away when the fault is fixed, possibly after you turn the bike off and back on.
