1 - 2 of 2 Posts
Hi I have a question. I have an online fuel pump on mr 07 1000. Its wired to the exhaust valve wiring for power. How do I wire it to the fuel pump wiring? I get no power to the fuel pump wires.
Power to the fuel pump is controlled by the fuel pump relay which is triggered by the ECM.
There is only power to the pump for a few seconds when the ignition is first turned on, (pump "prime"), when the bike is cranking and when it is running.
Yellow/Red wire is power in, Black/White is the ground.
I'm assuming you have checked the "fuel" fuse.
1 - 2 of 2 Posts
