I have a 05 GSXR 600, was wondering if any of you DIY'ers have installed a garage door opener on their bikes. I want to integrate it into the high beam swith. I bought a garage door opener at Wal-Mart earlier and was tinkering with it. I soldered the push button terminals together so whenever the clicker receives power it will send out the signal. Then I tried to wire the power supply into the High Beam fuse but I think I fried the circuit board because it stopped working. So anyways I exchanged it a little bit ago and before I screw up another one I was wondering if any of you guys had any ideas or knew where to wire it. It normally is operated on a 9Volt battery so I am thinking the bikes power supply is going to be too much. I am just an amateuer electrician so any ideas will help.
