1 - 17 of 17 Posts
NOPE will not work
Thanks! What about a same year 750?
I'm restricted to 600cc's and have a restrictor on the intake, so I'm trying to think of possible ways to get more air into it. I'm not all that familiar with these engines, so thanks for the help!
NOPE
now a 750 and 1k head will fit each other
try haveing work done to your ex head , port polish, over sized valves, and even some cams that will get you more air more hp.
Don't polish and if so just the exhaust side.
if you can find spare motor maybe (if money permitting) getting your crank balanced and knifed to make it pick up quicker. You may want to check on the newer generation heads as they may help you out
Discussion Starter · #8 ·
Thanks for all the input! I'm trying to learn as much about these motors as quick as possible.
Audi, we do have a spare motor which I've started playing around with. We're currently running the intake cam from the spare motor as the exhaust cam on the running motor and that has seemed to help out a little. I did some more research and found that the 2004 600 has slightly bigger valves, which might help. Do you have any idea if that will bolt-up to the '01 block? I'm also looking around for a cam that just lengthens the duration and doesn't change the lift, but I can only find cams for the 750 and 1000. Any sites that you recommend to look at to maybe find some?
Again, thanks for your guys help! :)
I am not sure but you can more than likely check with GSXRzone.com or contact me personally i will give you a person that does real good with power. can you deck the head or is that a violation? (its only cheating if you is caught.) this was something i have learned or heard thru the circle world
Discussion Starter · #10 · (Edited)
We removed 1 layer of the 3 layer headgasket, which bumped the compression up to about 12.5. We can do anything we want to the motor as long as it's displacement is under 610cc and it has to breath through a 20mm restrictor. Anything else is fair game. Thanks for the help and I'll send you a PM in a minute.
:cheers:
brandonlyons1 said:
turbo it!
I wouldn't think that would be a good ideal going into the first turn or second turn hahaha besides he would look like a kangaroo bouncing all over the track
yeah even at low psi the front just doesnt wanna stay down with a turbo...after half-way thru the rpms it'd come right up
Discussion Starter · #14 ·
brandonlyons1 said:
turbo it!
We've thought about it and we can get a couple free turbos, but the power gains really aren't there to warrant the extra work. With the restrictor, it basically just moves the power band up and down and doesn't really add much power.
Discussion Starter · #15 ·
lol I guess I should have told you guys what this is for.... it's for an FSAE car HERE is a picture of the one we're building right now. HERE is a picture of the same frame and you can see last years car in the background.
:cheers:
Ryan_McCauley said:
We've thought about it and we can get a couple free turbos ---------- I want a turbo how much since its free to yall. have you tried a NOS setup
try fitting a rotrex centrifugal supercharger. easy install, linear power delivery, light. my mate fitted it to his buell xb12 firebolt and doubled his TQ's and added about 30 HP's.
best bang for buck mod ever.
1 - 17 of 17 Posts
