hello guys, i own a gsxr 600 k7
i have an issue with the bike.. the idle just set itself a little higher by it's own.. i dont know how.. and when i pull the throttle grip to the front from where it sets by itself the rpms go lower.. also i cant adjust the idle cause of this i think something is wrong with the throttle cables adjustment or somenthing..can someone help??
flashed ECU,yoshi slip on exhaust and K&N air filter
Administrator
Welcome to the forum.
Try this. Start the bike up and then turn the handlebars full left and right and note if the engine rpm increases. That would be a sure sign the throttle cable need adjustment.
1995 GSX-R 750
Throttle cable adjustment time. It is in the service manual. If you don't have one, and have issues finding one, you can likely look up the correct procedure using the Google machine, on the interwebs.
