Welcome to the forum.Thanks for that. I have been advised it might be a fuel pump issue
Do you mean bogging when revved up or when under load and accelerating.Its bogging. The fuel pump seems to be fine. We think it might be the throttle valve actuator. it seems a bit stiff
"seems to be fine" is not a good answer. You need to do a fuel flow and pressure check to make sure it is working correctly. There are other things like o-rings and the pressure regulator that can cause low pressure or flow and hence, your issue.Its bogging. The fuel pump seems to be fine. We think it might be the throttle valve actuator. it seems a bit stiff
