1 - 10 of 10 Posts
MPG mod
On my K5 750 when I first start it daed cold it has a tapping noise from the motor like a bad valve adjustment. not so much a knock, its a light tap if i crack the throttle it goes away until it sits over night. anyone else getting this problem?
exact same thing on the 06 too. is this something we need to worry about since it goes away after it heats up??
Mael said:
GSXR's tap when they're cold. Its their way of remind you not to push the engine till it warms up.
Get used to it
:thumbup:
+1 It's a suzuki thing. Let it get to at LEAST 100 before pulling out and over 140'ish before you push it at all.
Your bike's fine. it's normal.
STREET MAFiA said:
i have the same problem..... :damn:
This is not a Problem... :hmmm: This is a normal operating characteristic of a cold motor/valve train.
Let the bike idle until it warms up. Don`t rev the motor when it`s cold. Internal eng. tolerance`s are the cause for this noise. Everything expands and contract`s with temperature change`s. Like someone else stated. Let it reach 100 deg. and then ride it. Let it come up to normal operating temp. and then you can flog it. :thumbup:
1 - 10 of 10 Posts
