K6 1000 engine squealing
285 Views 12 Replies 7 Participants Last post by  urbantoreador
8
Hi guys
Suddenly the engine after the rebuild squeels when cold,have done so far about 1200 Miles and no issue,now it does, have opened the engine and got this..please help
Has new engine bearings,thrust washer,cam chain,cam tensioner,valve seals,piston rings
Thanks
Automotive tire Nickel Bicycle part Rim Household hardware
Automotive tire Gas Rim Engineering Differential
Gear Automotive tire Rim Automotive wheel system Gas
Automotive tire Bumper Motor vehicle Automotive design Automotive exterior
Automotive tire Motor vehicle Gas Auto part Rim
Wheel Tire Automotive tire Motor vehicle Automotive design
Sent from my M2101K6G using Tapatalk
See less See more
Reactions: 1
1 - 13 of 13 Posts
Am I looking at some bearing scuffing?
Maybe check the clearances with Plasti-gauge?
Reactions: 1
Hi man
Checked it... within range,this is a used engine I thought same...but why squealing after that mileage? Worst crap should be fresh on not after doing over 1k miles, will update soon after doing other plasti run after fully cleaning seals and oil
Reactions: 2
The "squealing" description of the noise is strange. I would expect severe bearing damage if the noise was coming from the main and/or rod bearings.
When I hear that noise description, I usually think of the stator area first.
Reactions: 1
I don't know anything about the internals of one of these motors. Never had one apart, but are there any ball or roller bearing within one of the motors?
We are aware
  • Haha
Reactions: 2
Blkout sighting!
I hope you are well sir!
Yes, in KTMs. :ROFLMAO:
  • Haha
Reactions: 1
Have you pulled the engine apart again already?
Did you try and locate the source of the squeal with a mechanics stethoscope?
My guess would have been stator too although to me that is more of a whining sound.
Hi guys
Yes before pulling I used the estetoscope to hear, the squeal is only in cold and would even stall the engine, once warm no problem and the weird thing....no power loss
Have cleaned the casings for now...might also pull the head...if don't have to better...saves me a headgasket
Measurements are ok with the plasti,the thrust bearing are also fine,no marks on crank
I'm using the schnitz uprated oil gear and releaf valve,also a flo reusable oil filter now
I'm curious to hear what you determined the cause to be.
1 - 13 of 13 Posts
