Hi all, just joined this forum as i bought a K6 GSXR 600 last month. I found two issues with it recently:
1. The battery drains very quickly when the bike is off ( turns out the sidelights stay on all the time even after the keys are removed). Its a brand new battery
2. The Bike runs rough once it goes above 70degrees, and runs noticeably rougher above 90degrees.
I have just drained the fuel because I have no idea how old it is, and replaced it with Shells premium fuel and ran some injector cleaner through it. I ran the bike on idle for about 15 minutes to let the new fuel properly run through the system, and again once it got to 70 degrees and it started running rougher, and above 90 degrees ran even rougher. Its worth noting that it only seems to run rough at lower revs. Above 5k revs its much better.
I've been told by one person that it could be to do with the aftermarket exhaust its got on it (straight through), and been told by another person (a mechanic) that it sounds like the valve clearance needs adjusting.
I'm replacing the sparkplugs anyway so ill check them when i do so. Maybe the HT leads and coils as well?
Does anyone have any experience with problems like this?
