Ok I’ve read the rv6john thread and I’m pretty tech savvy but not as much with electrical stuff.
07 gsxr 600 15k miles bike stock other then dummy that gutted the stock exhaust so it throws that SET valve code but no others.
I got the bike kinda recently July 2020. i ride it quite a bit ran fine, went to a track day perfect everything is great. I ride it everyday it’s my only transportation rn I also work at Cyclegear so we ride as much to work as possible.
Anyway one day I rode to work and it was fine noticed a lil bog in high rpms nothing crazy (I needed to change the fuel sock still cause when I bought it the tank was a lil dirty so I just blew it out till the new one came in def not the problem) worked a whole shift went to leave and see a homies new bike, on the ride there noticed the bog was a lil worse when trying to merge. finally got to destination shut it off- went to leave bike wouldn't crank so I bumped started it. started fine and left, got half way home maybe 6 mins out of a 10-12 min ride home going the speed limit noticed the lights (cluster and headlight) getting dim, bike sputter and died right when I got home (lucky)- long story short- upgraded the stator, rectifier and battery. figured it was the stator cause it was so sudden. so I changed it, charged battery all the way tested it just incase, it was fine. started it let it run for bout 5 min turned off, turned bike on bike started fine, did that again felt weak so shut it off tried to start, wouldnt start. It would crank for a sec then click click click.
So I was like damn, I replaced the rectifier right after that thinking it wasn’t sending signal. bought a new battery from work also slapped them in, check battery (connection and volts) was fine, bike started fine. Ran bike long enough to get to temp. I shut it off like 7 times in between that and kept some revs on it, 8th try was weak, 9th try click click nothing checked the connectors they were all fine, fuses fine, I have power when I turn key on but won’t give enough power to start it (like a bad or dead battery but at this point everything is new) I’ve check it with a Multimeter and it says it’s fine so now I’m lost. I just suck at electrical stuff guys short of checking the whole loom for tiny knicks and a short I’m stumped. Might have to bite bullet and take it to the shop and I really don’t wanna do that plz halp
edit: I fixed all the bad spelling and punctuations I think.
