1 - 1 of 1 Posts
All you need to know about this Mod!
I would like to share the best mod i've ever done with low cost!
Gsxr 1000 k5 by ZIKOS DRAG TEAM, GREECE
Dyno tests are on same dyno with 9 days gap from 1st test to 2nd!
Dyno Before Mod Bone stock motor,head, etc.! (17/42T 530, full stainless steel Yoshi TRC shortened by half, K&N air filter, cutted velocity stacks, 12:5.1 comp stock)
Dyno after Mod (17/42T 530, Yoshi TRC, K&N, APE Adjustable cam sprockets, K8 stock set of cams, Brocks pin, ECU+PCV tune together, raised rpm by 240,
Cometic thin Head Gasket (no more than 13:0 comp. cant remember exactly)
Stock valve springs,stock valve diameter,stock pistons, NO porting NO nothing!
Also added AFAM 16/44T 520xsr light kit, Bottom short velocity stacks and wrapped air box with gold heat tape after dyno( that means few more NM and around exta +2hp top end)
180WHP TOTAL*( dyno pic will come soon before my next project in few months to ensure us about the exact WHP)
Next project is coming hot with
JE 13:8 comp pistons
porting Head
stronger valve springs raising rpm
Degree same cams
  1. *Your extra Advice welcome!
Dyno results are coming soon ( same mechanic same dyno)
Thanks!
1 - 1 of 1 Posts
