1 - 2 of 2 Posts
Hey guys, I have an aftermarket exhaust (Hindle) bundled with a PC V to install.
The exhaust doesn't have a port for the factory O2 sensor, so what can I do with it? Do I need an O2 sensor eliminator? Do I just cut it off? Tie it up? Disconnect it from the ECU?
Tried to search the forum but there are a lot of results to wade through.
Thanks
First... I am assuming you bought their full system, correct?
Do you have the ECU flashed or is it the stock ECU?
If it is not flashed you will either need to flash your ECU to eliminate the Fault Indicator (FI) code that will come after install, or buy an o2 Eliminator (plug and play) to replace the stock o2 sensor.
Do not cut it as you might need it late or can sell it and don't install the exhaust until you complete one of my other options.
1 - 2 of 2 Posts
