1 - 2 of 2 Posts
Hello My name is Mark:
I have a 08 GSXR 1000 drag bike project. I want to leak down test the motor this winter, and split the cases and check the bearings. What leak down tester should I buy? I had a problem with my compression tester kit the fittings are not long enough and get stuck in the spark plug hole. It is like I need some type of extended fitting that sticks out past the valve cover so I can unscrew it. can anyone help?
Thanks,
Thanks,
Search for "engine leak down tester extensions"
1 - 2 of 2 Posts
