how can i get more compression out of my motor with out changein the pistons, if i deck the block or head will that give me more?? what about gettin a thinner head gaskit?? has any one done this???
yes, but higher compression alone will not net a ton of gains....... if you raise the compression in conjunction with other mods internally it will be wrth a bit more.
is it worth it if i do the cams, port polish the head??
sure is. But you will limit yourself to proably just about having to run race fuel to avoid detonation. Not nesscesarily but could depending on how fr you take the compression.
