NOTE: 999cc's
TECHNICAL SPECIFICATIONS:
Overall Length: 2,030 mm (79.9 in)
Overall Width: 710 mm (28.0 in)
Overall Height: 1,130 mm (44.5 in)
Wheelbase: 1,405 mm (55.3 in)
Ground Clearance:
Seat Height: 810 mm (31.9 in)
Dry Mass: 166kg (366 lbs)
Fuel Capacity: 18 litres
ENGINE:
Engine Type: 4-stroke, liquid cooled, DOHC, 4-cylinder
Bore x Stroke: 73.4 mm x 59 mm
Max Power:
Max Torque:
Piston Displacement: 999 cc
Compression Ratio:
Carburettor: Fuel injection 44 mm
Lubrication:
ELECTRICAL SYSTEM:
Ignition Type:
Starter System:
TRANSMISSION:
Clutch:
Transmission: 6-speed, constant mesh
Drive System: Chain
CHASSIS:
Front Suspension: Inverted telescopic, coil spring, spring pre-load fully adjustable, rebound and compression damping force fully adjustable
Rear Suspension: Link type, oil damped, coil spring, spring pre-load fully adjustable, rebound and compression damping force fully adjustable
Rake/Trail: 23.8 degrees/96 mm (3.8 in)
Front Brake: Radial mount, 4-piston calipers, 310 mm dual-disc brake
Rear Brake: 2-piston caliper, 220 mm disk brake
Front Tyre: 120/70 ZR17M/C (58W)
Rear Tyre: 190/50 ZR17M/C (73W)
