So i took my Yoshi RS-3 and cut it down to about 10". it sounds SICK!!! loud, probably a little bit louder than i'd like but it's still pretty sick.....question is does anybody have some knowledgeable advice on what would be a comparable exhaust to use with my PCIII? it used to lope a little bit and i loaded the full exhaust map and it solved the problem and now it lopes a little bit again.
also, when you re-stuff baffling, is there some that will quiet it down more than other stuff? i used the original baffling just cause i didn't have any new stuff and it's sunday so everything is closed. i'm going to open it up cause i kind of had to rig up the center tube..it works great but when i re-stuff it, i want to get the tube normal again.
last thing, can you put a silencer on a yoshi RS-3? just for cruising around that might solve the volume issue...or in the neighborhood.
thanks for the help..here's a pic...it kinda sucks cause it's dark..but you get the idea. never mind..can't figure out how to add a pic if somebody wants to help out with that too...i don't have a pic with a URL...just wanted to upload a pic. thanks guys.
