Available for right around $40 on Amazon I took a punt and ordered a set for the yellow submarine. The why is detailed in another post but suffice it to say I ordered the set for a reason.
I installed them shortly after they arrived yesterday. It was a simple and straightforward install. Only took me the 20+/- minutes because I cleaned up the pivots and regreased everything.
The good is; the look really nice. Billet and black anodized with anodized red adjusters. Finish is quite nice visually. Functionally? Not exactly.
I have sets of very high quality CRG levers on another bike and some similar ones from Pazzo on my 996. Both are exceptionally well engineered and the adjusters work really well. These MZS levers are not in the same league though.
Thing is they’re not horrible either. The problem for me is how they function for me and my expectation of how they should. That’s where things get a bit messy.
1st off the levers don’t fit as precisely as the CRGs or the Pazzos. The clutch lever is sorta floppy like the el cheapo Cycle Gear lever that it replaced. To be fair, there are some included shims that I may try this weekend to see if that tightens things up a bit.
The brake lever is a different yet similar story. The OEM lever is fine and may well go back on. The thing is, the MZS lever has a funky kink in it. This brings the lever closer to bar. Fine for maybe my wife and her tiny hands.
With my gloved mitts though that kink hits my ring finger if I use the 2 finger braking I’m used to. If I use 3 fingers it’s fine. I adjusted the lever all the way out at its highest setting and still not much change in the result. There in lies my other issue. It feels like there is excessive free play at the outer end of the stroke. Almost a half inch.
That brings me to the adjusters. While definitely nice looking when adjusted to the fullest both adjusters are comically swept to the point of looking like they’re off the numbered adjustment scale.
In actual use, the clutch works just fine. The brakes….annoying. The more I think about it, the more I feel like swapping back to the OEM brake lever. I’m going to try and get the free play down to more like 1/8” or so first as I think that will alleviate my issues.
I guess for under $40 I shouldn’t be as critical but hey, my expectation was not exactly met. As I stated up front though, they do look very nice. Once I get them sorted (or replaced) I’ll post further impressions.
If I had to give a numbered rating of my initial impressions, I give them a 5 out of 10 for function. 10 out of 10 for cosmetic quality. Overall, based on those 2 scores 6 out of 10.
