1 - 8 of 8 Posts
i am trying to tighten down the assembly on the handlebars that has the on/off switch and starter button.. it seems that no matter how tight i tighten the screws the things still turns... is there some glue or something that is suppose to be on this.. oh by the way this is on a 02 gsx-r750
Like earlier post stated but those things have a little pin that break rather easily
ok so i just took the switch apart and yep the little plastic tip is broken.. does anyone have a way to fix this without buying another assembly..
Get something of a little smaller than what was on the hole or just get a small screw. turn it into were it broke then get some JB weld and cover it up. When it hardens you should have a pin to stick into the hole to stop it from spinning round. Make sue its a small screw and also when the screw is in you can get a cutter or shear off the head of the screw
Super glue!!!!!!!! :laughingr :laughingr
1 - 8 of 8 Posts
