I did a search and did not come up with much. It seems like a simple answer but not sure it is.
Bike ran fine at the end of last winter. This season I changed the plugs as they where about 5 years old. Stock when new. Not sure what I got, what ever they gave me really. Odd thing here is dealer repair manual says gap should be .07mm and old ones that came out where only about .03mm. I looked at the .07mm and said yeah I don't think so and went with the .03mm gap. Got everything done and went for a ride today.
Sometimes and not all the time the bike likes to stutter on the low RPM range when I am coming off the gas. Decelerating after being on it and thats when it starts to stutter and sometimes to the point of a stall. If I pull the clutch in it will stall I will let out the clutch gas it and it will go again and so it continues.
This happen off and on all day, seeming to be better when the bike was above 210 on the temp side and doing this more often when below 180. It was only 45 out today so not the best day out.
Could this be the cold weather, the plugs?
Stock computer with aftermarket pipe and ran fine until I changed the plugs this year? Should I disconnect battery and let it remap itself for the colder weather right now?
No FI codes either?
Stummped alittle on this one.
Thanks in advance from anyone that can shed some light.
No FI codes either?
