I just bought a 98 GSXR750 an upgrade from my 750 Vulcan. And have been running it for about a week and now i'm having problem's with it. i'm woundering if any one can help me out.
Not likely if you don't tell us whats wrong with it.i'm woundering if any one can help me out.
Im not sure you quite understand what an Ohm meter is for. To check Ohms you check it with the circuit DEAD, ohms simply tell you how much resistance is in a circuit. To check a fuse you want to check for continuity, just put the meter on each end of the fuse, if you have continuity the fuse is good, if you dont its bad. Continuity just tells you the circuit is complete. Depending on what kind of meter it is it will have settings for alternating current/AC (~V on the meter) and direct current/DC (-V on the meter), obviously on the bike you want the DC/-V setting on the meter. You can use this to make sure your getting proper voltage where you should be.I got an ohm's meter today from a friend so i can test all the curents and make sure there putting out like they should. I need to find out under the Fglass under the seat's there is the 30amp fuse under plastic what is the ohm's for that front and back?
Could be wrong but can’t you blow gaskets ect.. if it’s to fullnever heard of a problem from putting in too much oil.
:headscrat
I know in a car it could possibly blow the seals around your pistons.welcome 2 da site
