1 - 13 of 13 Posts
Go into Paint, and stretch/skew it down to like 70% or 80%.
1986 Gsxr 7/11
Had To Manipulate The Photo But Here Is My 86 Gsxr 7/11. Look Different??? Updated With 92 Upper, Wheels, Headlights, And Tail Section. 88-90 Mids And Lowers. Changed Out Signals, Added A L.e.d. Brake Light To The License Plate, Kept The 86 Gas Tank, Forks, Frame, Sub Frame(but W/ Mods), Installed A 1100 Motor, Individual Air Intake Filters, Lowered Three Inches, Stretched About 4 Inches, 180 Rear Tire, And A Little Chrome Here And There. Temporary Paint Except Tank.
Looks really good man, very clean for an older bike. Good work!
Welcome.. mad props on the work you've put into it.. very clean :clap:
Discussion Starter · #13 ·
I Cut Off The Top Of The Forward Seat Mount(closest To The Battery), Folded Over The Left-over 2" Peices Until Somewhat Flat, Then Used Some 1 1/4" Aluminum Angle Bar (for Strength) To Make The New Forward Mount In A Lower Position. Drilled New Holes For The Latching Mechanism. Had To Also Mount Up Some 1 1/4 Inch By 3 Inch By 4 Inch Rectangle Tubing "extension Blocks" To The Subframe So That The Rear Sets Would Sit Close To The Right Position. Used This Size So That I Could Get Three Bolts Secured To It. Maybe I Could Just Send Ya A Picture! That Would Be Easier Than A Description! Send Me Your E-mail So That I Can Send You That.
1 - 13 of 13 Posts
