1 - 3 of 3 Posts
I moved out to Vegas and my bike say in a loving truck for a few days took it out and took for a ride realized I was leaving a trail of oil and what smelled like gas o think it’s coming out near the stator case or I believe water or oil pump. Here are the pictures where might the leak be I’m taking the fairings off but it’s everywhere
You will need to pull the front sprocket cover off and any other surrounding pieces to confirm where the oil is. I suspect that its coming out the shift shaft seal but there is no way to be 100% from these pictures.
^ What he said.
Also, check the oil level in the crankcase. There is a good possibility the fuel valve and carbs leaked past and you have fuel in the crankcase. The fuel will go past a worn seal easier than oil alone.
Reactions: Spyder13
1 - 3 of 3 Posts
