i have the manual for the 06/07 600 if u want it...shoot me your email :thumbup:Search on here for your year repair manual. It'll have detailed instructions to do all types of maintenance on your bike
its essentially the same thing...
remove the oil drain plug, replace the oil filter, put the oil drain plug back, and then refill the oil
I have a K7 750 and I don't pull the plastics completely off. I pull the bolt out of the bottom by the sidestand and I pull the clip that holds the two fairing together in the front directly behind the front tire. Then I just pop the little rubber plugs out and it gives me just enough room to wiggle the old filter out and the new one in.i have a question, has anyone ever changed there oil and filter without taking any of there plastic off? I know that might be a dumb question, but i was just wondering.
please please please change your oil filter EVERY oil change. Put it this way. You have a water filter system and the water is brown and nasty and you just dump the old water and add fresh clean water. As soon as the clean water makes just a couple cycles through that nasty filter, Would you drink it?one more question, i was looking in my owners manual and it says in it that for the oil changes its every 3500 miles (600,4000,7500 miles etc) and for the filter it says that you have to change the filter about every 3 oil changes. so that is my question is it ok to follow what the book says, and change the filter about every 9000 miles? cause i changed my oil the first time around 700 miles and i have 3300 miles now, so im wondering if it would be ok to skip on the filter this time like the owners manual say.
hey man..got ur email but it came back as invalid...did u send me the right one????I need a write up please if anyone knows of one.
i saw one on here for an 04-05 600 with pics which is exactly what im looking for but i need one for my bike
please let me know if you know of one on this forum or any others
i searched and can't find one
No, change your filter every oil change...why risk anything?well i was just looking threw my owners manual and i seen in there that they say you dont have too change your oil filter every oil change. would it be ok to change it every other change?
Dude.... the oil drain plug is going to be the lowest plug.... normally....lay down and look at the oil sump. Figure it out. There is only going to be one oil drain and that makes you lucky. Buy a high speed K&N oil filter every time you change the oil. Well I guess you can just get the suzuki ones if you don't want the thrills. Anyway hehehehe. Man it aint no big thing to change the oil. Possibly one day there will be internet controllable robots to handle problems like this and you could pay me to click click to change your oil and filter.
1. The lowest bolt looking thingy I'd bet is at an angle to the rear is your oil plug.
2. It will be much easier next time around
3. Don't leave out putting oil on the filters gasket.
4. Don't rev engine for a few minutes after first starting after changing oil.
5. My 1000 takes almost all a jug of Motorex oil but yours probably not as much.
6. Don't use car oil
7. Make sure you buy a ring gasket for the oil plug AND install it.
8. Quit scaring us man.
