1 - 9 of 9 Posts
So I removed the air box on my 2000 GSXR 600 to change the plugs the other day. I noticed an oily sludge running down the airbox so I removed the filter to inspect. There was shit all over the place. I had left my bike in the rain a few days in a row and when it was pouring outside. Could this sludge be the oil off the K&N mixed with rain water? I cleaned it out and it runs much better. I'm sure changing the 18k mileage plugs didn't hurt either. Thanks dudes.
probably a mixture of K&N sludge, crank case breather blow by, and moisture. Probably had zero effect on running, but a good idea to clean it out
also make sure you fill the oil to the correct level or as stated you will get it in the airbox
Pretty much guarantee that its just rain water mixing with the K&N oil and the blow by. The pcv valve vents the extra crank case pressure to the airbox for reburn. A lot of oil in almost vapor form flows with that extra pressure, over time this will make the mentioned 'sludge'.
+1 on the crank case breather blow...
1 - 9 of 9 Posts
