I think this is the oil carbon. I would check one of the valve stem seals for worn and elasticless.Intake valves full of carbon
That marks look likes a result of overheating or oil starvation (clogged oil jets maybe?). Have you a photo of the corresponding side of the piston?Bought the engine second had
Did lower rebuild but knock is still there
Flex honed barrels and with less than 2k km the marks are there
Toss in some Redline SL1 for two tanks then check the throttle bodies. Your fueling could be off or a sticking injector.Intake valves full of carbon View attachment 299936 View attachment 299937
Sent from my M2101K6G using Tapatalk
If you remove the stator cover I know on my K7 I can actually inspect the rods and lower cylinders with a flash light behind flywheel. Deff cyl # 1,2 cyl 3,4 might be harder to inspect. I do see that triangler mirror finish on wall in the bore which looks polished.Intake valves full of carbon View attachment 299936 View attachment 299937
The knock is the sameMy valves are heaps worse then that. But the engine still runs good though.
I've had my crank vent hose disconnected for the last 40K, after i cleaned my valves. But they are
back to about the same now. So the carbon is not coming from the crankcase pressure, but more
likely valve stem seals (as mentioned above).
But from your other post, you mentioned that you changed the valve stem seals. So i'm not sure
whats going on there. Maybe yours is coming through the crank case?
Also, the knocking sound from your other video, could it be from the clutch area?
Is the knock worse with the clutch lever pulled?
There was a guy on here who had loose pins on the back of his clutch basket.
Just a thought.
As I saw in the photo of the valves, your valve stem seals are leaking. So warm up the engine, and then measure the compression ASAP.Got 14 bar out of it
