Ok so I found a motor with only 450 miles on it, after mine blew up. I got it in and everything was good.
I had to drain and remove the radiator when I did the swap, so of course had to refill once everything was done.
Well it started up and was running fine in the garage, but I noticed that the temp was climbing pretty fast.
It got to around 215 and the fan came on and next thing I know it's at 252, and the numbers 252 are blinking. I figured that wasnt good so I shut her down.
This happened twice.
I came on here and red about burping the air from the top screw of the water pump, so tried that, but it's still getting hot.
Is there more air bubbles or what??
Does anyone have anything that will help me. Or know something I don't.
Or is this normal if you let a bike idle for 8 minutes or so...
Thanks
Thanks
