ok..so I switched from a 600 motor to a 750 motor over the winter. I finally got all the parts I needed to get it going..so I try her out today... it started but didnt sound right...so it turns out only 2 cylinders are running.
here is what we checked so far.
- added new gas
- new plugs (tried swapping plugs from the working cyclinders with same result)
- tried switcihg around the coil packs
- checked each cyclinder for spark (all getting strong spark)
- switched around the injectors with same results
- removed fuel rail and saw each injector working
It got dark so I will continue tomorrow. Can anyone suggest any other tests? We are going to do a compression test..Im gonna be soo pissed if the motor is messed up...
- added new gas
