Hi,
I'm new to the forum, so apologies if this is covered in other threads.
I have a PCIII USB fitted to a K4 and it currently works fine.
I have now fitted a Multi Function Hub and Map Selection Switch. I know that I now have to load a second map into the PC to use the Map Selection Switch.
I'm seeking help because the documentation is a bit lightweight for a newbie and I've already had problems with updating the firmware, because I did it with the engine running (OOPS - Never do that again).
The PCIII now has the correct firmware version loaded and I now have access to the Set Nums Maps option in the drop down menu. If I go to use the two maps option, I get a request to confirm that I want to reset the unit and a warning that it cannot be undone. I'm not sure why it can't be undone, but the warning is a little off-putting given my previous problem.
Has anyone done this before and provide any advice.
Also, can the maps be changed while the engine is running on the GSXR, or should I use the 9V adapter. I assume that the hub does not need to be connected when loading maps, as it plugs into the same socket as the 9V adapter.
Any advice/help would be greatly appreciated.
