1 - 16 of 16 Posts
Hello, everyone. I bought Power commander 3 serial to GSXR 1000 K1-2. The harness has two large 16-pin connectors and there should be two small 2-pin connectors . They cut me off a little bit . What are small connectors for ?
Reactions: Todd_Sails
Thanks for the reply. But there is no pinout of wires by color in the instructions. And I have a power commander 3 version without usb.
Bummer. I thought I remembered seeing a diagram in the back of the manual.
Shoot DynoJet an e-mail, they have been pretty good with customer service. At least pre-C.
Translation: Thank you, I will try to write them."
Reactions: rv6john
Sorry I'm writing through a translator) Didn't you pay for the decoder ?
No problem, Google translate is free. Your translator is good! What are you using?
Discussion Starter · #15 ·
Maybe it will be useful to someone. I received a response from dynojet. A small connector is used to connect the crankshaft sensor. The engine speed is read from it. But you can not connect it. Then the engine speed will be read from the injector pulses. Thank you all for your help.
Good info, thanks.
1 - 16 of 16 Posts
