Need some help with wireing on my gsxr any one willing to add me on face book to talk it out? Building it in my apartment
Most of us old farts don’t FB. I for one, do not. The why has nothing to do with techno phobia and is a discussion for another time and thread.Won't be going the Facebook route, this will prove way better.
Its a 750 i have to clock the starter but other then that im not getting power from start swich i have light on dash and a red oil light but i bypassed the kickstand switchHey, I got your message. Yeah we can help you. What are you looking for? Won't be going the Facebook route, this will prove way better. Is that a 750 or a 1100?
yes will do! in my fuse pan has 10 amp fuses all along it. i have a band new battery but i will check the voltage tho. im stumped it could ALSO be the clutch switch im not to sureOK. Check your fuses, there should be a fuse at the starter relay under the battery box. It may be the culprit. Also check your battery voltage and grounds.
but i haver a constant red oil light also changed out the cdiyes will do! in my fuse pan has 10 amp fuses all along it. i have a band new battery but i will check the voltage tho. im stumped it could ALSO be the clutch switch im not to sure
any way you could post a pic of behind the headlight like all the wires and connectors ?yes will do! in my fuse pan has 10 amp fuses all along it. i have a band new battery but i will check the voltage tho. im stumped it could ALSO be the clutch switch im not to sure
a 30 amp fuse on the relay itself?The oil light will be on until the engine is running. When the engine is off there is no oil pressure and the light will be on as it should.
Follow the big wire from the battery area to the starter relay. Starter relay should be mounted under the battery box. There should be a 30A fuse there. I suspect that may be the issue.
I can post a pic when I get home later tonight. There is a video in my thread. I will try to dig it up for you.
ok I'm checking around i found something called a breaker 30amp im new to the electrical side so how would i test it and what reading should i look out for its black and has a red dotok thank you i never noticed a fuse but i could have missed it let me go look no
there is no beep but reeding is same when i touch probes together and when i probe the part
I'm stumped on this thing started turning backwards iv tried to clock 5 timesMost of us old farts don’t FB. I for one, do not. The why has nothing to do with techno phobia and is a discussion for another time and thread.
However, some of us actually worked professionally as mechanics and have decades of experience with electrical systems. Some of us have even been to school for the job and have formal classes in electrical diagnostics.
We can help, but only with accurate information.
